Hey guys, video URL here:
Free video clip with Taiwan IP needed.Code:https://video.friday.tw/drama/detail/2275/%E5%8B%BF%E8%AA%AA%E6%98%AF%E6%8E%A8%E7%90%86-%E7%AC%AC1%E9%9B%86?episode=75761&index=1
I just ran into this problem that, when I was trying to send a POST request, it always returned this error:
I have connected to my Taiwan IP already, and it went normal on my Chrome browser, but this error always showed up when using Python.Code:urllib3.exceptions.SSLError: [SSL: WRONG_SIGNATURE_TYPE] wrong signature type (_ssl.c:1006) requests.exceptions.SSLError: HTTPSConnectionPool(host='widevine.video.friday.tw', port=443): Max retries exceeded with url: /?deviceId=Mzg4....NGNk (Caused by SSLError(SSLError(1, '[SSL: WRONG_SIGNATURE_TYPE] wrong signature type (_ssl.c:1006)')))
I thought it was something to do with my Internet, so I restarted my laptop as well as my Wi-Fi, and also my proxy.
Then I tried with some other sites, but the situations were pretty well, with keys being retrieved quickly.
And I used curl to duplicate this request:
and an HTTP 500 returned so it's not like the Internet connection is bad or something else, it seems like the error happens only in this site.Code:curl -X POST "https://widevine.video.friday.tw/?deviceId=Mzg4....NGNk" --data "abc"
So would anyone be willing to help me?
				Results 1 to 14 of 14
	P.S. I also went to some online sites like getwvkeys to do this test, as I found out that only this deviceId parameter is crucial, and the license server won't authenticate other params.
 And it was also normal, no key-value pairs in the headers. (And then I deleted all the headers in my Python script but it didn't work.)
 [Attachment 74989 - Click to enlarge]
	I also encounter the same SSL connection problem of friDay recently. Finally I follow the shorter version of the solution in this link https://stackoverflow.com/a/69580908 and it resolve the connection issue.
	I'm a bit confused about the role these codes play in. But is this the right way?
 I changed the 'res = session.get(url)' to 'res = session.post(url)'Code:import requests import ssl url = 'https://widevine.video.friday.tw/' class TLSAdapter(requests.adapters.HTTPAdapter): def init_poolmanager(self, *args, **kwargs): ctx = ssl.create_default_context() ctx.set_ciphers('DEFAULT@SECLEVEL=1') kwargs['ssl_context'] = ctx return super(TLSAdapter, self).init_poolmanager(*args, **kwargs) session = requests.session() session.mount('https://', TLSAdapter()) res = session.post(url) print(res)
	Right, place the related coding in your l3.py. Just like below.
 Code:... import ssl class TLSAdapter(requests.adapters.HTTPAdapter): def init_poolmanager(self, *args, **kwargs): ctx = ssl.create_default_context() ctx.set_ciphers('DEFAULT@SECLEVEL=1') kwargs['ssl_context'] = ctx return super(TLSAdapter, self).init_poolmanager(*args, **kwargs) def WV_Function(pssh, lic_url, cert_b64=None): wvdecrypt = WvDecrypt(init_data_b64=pssh, cert_data_b64=cert_b64, device=deviceconfig.device_android_generic) session = requests.session() session.mount('https://', TLSAdapter()) widevine_license = session.post(url=lic_url, data=wvdecrypt.get_challenge(), headers=headers) .....
	I wonder if this is a problem with the old WVKEYS implementation, or if this happens with the official pywidevine module as well?
	oh no , @Obo what you said is right. and i just tested this tile with new pywidevine(1.5.3), just input pssh and license url, no header needed, it worked.no ssl problem.Code:https://video.friday.tw/drama/detail/3190/%E7%94%B7%E6%89%AE%E5%A5%B3%E8%A3%9D%E5%AE%B6%E6%94%BF%E5%A9%A6-%E7%AC%AC6%E5%AD%A3-%E7%AC%AC1%E9%9B%86?episode=99359&index=1
 [Attachment 75014 - Click to enlarge]Last edited by shellcmd; 23rd Nov 2023 at 04:59.
	From my understand, this issue is due to SSL/TLS connection. The client (Python use openssl with higher security level) initiate TLS connection to the server (with lower security level). Both sides cannot negotiate the same set of cipher to start the connection eventually. The provided coding is to lower the security level of client side. Alternatively, if you could use the older version of openssl, it may connect without issue.
	Using below link, it can check what cipher suites are supported by the target site. Your Python client (openssl) should support one set of these cipher suites.
 https://www.ssllabs.com/ssltest/analyze.html?d=widevine.video.friday.tw
 I have found another link https://hussainaliakbar.github.io/restricting-tls-version-and-cipher-suites-in-python-...ith-wireshark/. It explicitly set the cipher suite. For the first try, you may set this supported cipher in your coding. I have not tested it yet, hope it can resolve your issue.Code:Cipher Suites # TLS 1.2 (suites in server-preferred order) TLS_RSA_WITH_AES_128_CBC_SHA (0x2f) WEAK 128 TLS_RSA_WITH_AES_256_CBC_SHA (0x35) WEAK 256 TLS_RSA_WITH_AES_128_CBC_SHA256 (0x3c) WEAK 128 TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 (0xc030) ECDH secp384r1 (eq. 7680 bits RSA) FS 256 TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 (0xc02f) ECDH secp384r1 (eq. 7680 bits RSA) FS 128 TLS_RSA_WITH_AES_256_CBC_SHA256 (0x3d) WEAK 256 # TLS 1.1 (suites in server-preferred order) TLS_RSA_WITH_AES_128_CBC_SHA (0x2f) WEAK 128 TLS_RSA_WITH_AES_256_CBC_SHA (0x35) WEAK 256 # TLS 1.0 (suites in server-preferred order) TLS_RSA_WITH_AES_128_CBC_SHA (0x2f) WEAK 128 TLS_RSA_WITH_AES_256_CBC_SHA (0x35) WEAK
 Reference of Openssl supported cipher sites:Code:TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 ECDHE-RSA-AES128-GCM-SHA256 TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 ECDHE-RSA-AES256-GCM-SHA384
 https://www.openssl.org/docs/man1.1.1/man1/ciphers.html
	New information to me. I'll check them.
 Really appreciate it @yawoo.
	I find another link that may be useful to you. The latest OS use Openssl v3 that remove unsecure Ciphers by default and cause the connection issue with the server with weak Cipher suite. You may refer his coding example.
 https://stackoverflow.com/questions/77262501/how-to-alter-cipher-suite-used-with-python-requests
 PS. My Python 3.10.11 (in Windows 10) still use Openssl 1.1.1
	I refer to handshake simulation on OpenSSL client in SSL labs report, and select the cipher AES128-SHA.
 Code:Handshake Simulation OpenSSL 1.0.1l R RSA 2048 (SHA256) TLS 1.2 TLS_RSA_WITH_AES_128_CBC_SHA No FS OpenSSL 1.0.2s R RSA 2048 (SHA256) TLS 1.2 TLS_RSA_WITH_AES_128_CBC_SHA No FS OpenSSL 1.1.0k R RSA 2048 (SHA256) TLS 1.2 TLS_RSA_WITH_AES_128_CBC_SHA No FS OpenSSL 1.1.1c R RSA 2048 (SHA256) TLS 1.2 TLS_RSA_WITH_AES_128_CBC_SHA No FS
 Below coding is working in my environment, for your information please.
 Code:... from requests.packages.urllib3.util.ssl_ import create_urllib3_context CIPHERS = ( 'AES128-SHA:AES128-SHA256' ) class TLSAdapter(requests.adapters.HTTPAdapter): def init_poolmanager(self, *args, **kwargs): ctx = create_urllib3_context(ciphers=CIPHERS) kwargs['ssl_context'] = ctx return super(TLSAdapter, self).init_poolmanager(*args, **kwargs) def WV_Function(pssh, lic_url, cert_b64=None): wvdecrypt = WvDecrypt(init_data_b64=pssh, cert_data_b64=cert_b64, device=deviceconfig.device_android_generic) session = requests.session() session.mount('https://', TLSAdapter()) widevine_license = session.post(url=lic_url, data=wvdecrypt.get_challenge(), headers=headers) ...
  How to merge video m3u8 url and audio m3u8 url live channelBy sairaj in forum DVB / IPTVReplies: 2Last Post: 3rd Jul 2023, 07:29
  License url error, I can't get the keyBy Brift_Bv in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Jul 2022, 12:20
  DVD Decrypter: no Read Errors, but Retries?By guy24s in forum DVD RippingReplies: 2Last Post: 27th May 2020, 14:37
  Merging url video and url audioBy lafamar in forum Video Streaming DownloadingReplies: 7Last Post: 9th Apr 2020, 04:52
  Any Black Friday recommendation for best tool for video editing?By foton24 in forum EditingReplies: 19Last Post: 22nd Nov 2018, 17:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
